Latest post 05-23-2008 5:24 PM by Toby. 3 replies.
Page 1 of 1 (4 items)
  • 05-20-2008 4:00 PM
    • Top 75 Contributor
    • Joined on 04-01-2007
    • UK
    • Posts 970
    Serene is changing 0 prefix numbers to +44
    I share phonebooks between BeoCom2, 6000 and a Serene however, the serene replaces 0's with +44. Its causing me a problem with MMS is there a way to stop it?
  • 05-20-2008 6:33 PM In reply to
    Re: Serene is changing 0 prefix numbers to +44
    Are you sure it's the + thats the problem? As all mobiles use + instead or 00...
  • 05-21-2008 2:42 AM In reply to
    • UK
    • Posts 970
    This is what I am trying to do:-
    Messages
    Create
    Multimedia message
    Add image
    photos
    Add
    Send
    "To:"
    phonebook
    I select my other mobile, +447923.....
    I get the message "NOT AVAILABLE"
    I type in my mobile number 07923......
    Then it tries to send
  • 05-23-2008 5:24 PM In reply to
    • Toby
    • Top 500 Contributor
    • Joined on 04-16-2007
    • Hertfordshire United Kingdom
    • Posts 136
    That should not be a problem I have had my Mobile numbers saved with +44 for the last 12 years. Never had a problem.  I can only think your SIM is not cleared for foreign lands.
    Ring your provider and ask.
    Or even quicker have you used your phone outside the UK yet?  If not have it cleared for using abroad and see if that changes anything. This does not cost extra.
    Kind Regards Toby
    I better do my bit and suspend my siggy.
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
