Latest post 05-09-2008 4:35 PM by Peter. 1 replies.
Page 1 of 1 (2 items)
  • 05-09-2008 3:55 PM
    Beocenter 9000 - MCP 5500
    Could anyone please tell me if the MCP5500 is compatible with a Beocenter 9000?
    From brief trials it appears to control the basic fuctions i.e. on/off..CD/Radio/Tape/Aux etc
    I currently use the Beolink 1000 to operate all the functions on the BC9000 such like volume/treble/bass etc
    Is the MCP 5500 compatible in that, will it permit me to change the volume/bass/balance/treble settings?
    Currently I haven't got a clue how to do it - perhaps it won't?
    Any help or manual would be appreciated.
    Cheers.
  • 05-09-2008 4:35 PM In reply to
    Re: Beocenter 9000 - MCP 5500
    You won't get two way communication and although it might work a bit one way, it will not be reliable - My advice is don't do it! The Beolink 1000 is much better!
