Latest post 05-08-2008 3:10 PM by Die_Bogener. 3 replies.
Page 1 of 1 (4 items)
  • 05-06-2008 5:14 PM
    • Xseries
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Hampshire
    • Posts 433
    Penta III Warning Light
    Off at mains - nothing (harrdly surprising!)  On at mains - red light
    Switch on Beosystem - green light and green display  work fine - sit back and enjoy music
    Off using BL 7000 - red light
    So far so good......
    10 minutes later the red light (on one side) turns orange.  Does anyone have any ideas why??
    As a result I do not tend to leave the speakers on standby....
    Thanks for any thoughts.
  • 05-07-2008 2:18 AM In reply to
    Re: Penta III Warning Light
    If the warning light turns yellow/orange then the protection circuit been activated because of a detected fault which normally means:-
    • The amplifier unit has overheated,
    • A fault occurred in the amplifier which could damage the loudspeaker units.
    Assuming this never happens whilst the speakers are in use (playing music etc), then the fault is likely to be power supply related i.e. it is drawing more current in "Standby" than it should
    Regards Keith....
  • 05-07-2008 2:48 AM In reply to
    • Xseries
    • Hampshire
    • Posts 433
    Thanks for that - any (easy) remedy?
  • 05-08-2008 3:10 PM In reply to
    Do you have a pet... cat or dog? Cool
    ... and some wet yellow stuff around the Penta? Devil
