Latest post 05-01-2008 2:36 AM by Medogsfat. 1 replies.
Page 1 of 1 (2 items)
  • 04-29-2008 2:31 AM
    Which DIN cable?
    I managed to snag a pair of S80s. I haven't received them yet, but I hear they only have a DIN socket.
    Is this correct? If so, is it the 2-pin type?
    Also, what gauge wire can I use with 2-pin DIN? I think I'll just buy the plug from my local electronics store and solder it to some hifi wire.
    Filed under:
  • 05-01-2008 2:36 AM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    Re: Which DIN cable?
    Yes they are the standard 2 pin DIN fitting as on most B&O speakers.
    Any decent speaker wire will be just fine, don't try for anything too thick as it will cause problems when soldering the plugs. I have known strands of wire inside the plug body to become free and cause problems with shorting.
    Chris.
