1st March February 2012
04-28-2008 5:19 PM
benoit
- Joined on 10-11-2007
- Posts 124
Re: BV8 News This Summer!!!
Is this for BV8-26 or only for BV8-32? A dealer in Marseille (France) told to a friend of mine that the 8-26 wouldn't be available anymore in France because of no integration of DVB-T.
The Stig - ver. 1.7
- Joined on 06-20-2007
- Posts 898
It's both. some of the early 26" do need a modification to the power supply. Cut be that there is coming a larger BV8 at some point.
benoit
- Posts 124
Any idea of the price for a 8-26 (without Beo4)? Thanks
benoit
- Posts 124
And will this work with my old Beo4 (without DTV A.MEM V.MEM) or do I need to upgrade it or buy a new one?
The Stig - ver. 1.7
- Posts 898
Yes DTV is the same as SAT  so will work just fine
Keith Saunders
- Joined on 04-16-2007
- Technical Advisor, Little Ann, Hampshire, UK
- Posts 3,810
DVB-T is an MPEG-2 decoder which in the UK means Freeview. The question is, will this new integrated DVB-T also decode MPEG-4, lets hope so..
Stars
- Joined on 04-24-2007
- London
- Posts 1,483
Thanks for that. Will this be an option if buying a BV8 in the future? My Freeview box is also my Italian channels box, so I doubt the built-in one would've been much use to me.
Keith Saunders
- Posts 3,810
Henry, If you have a dedicated "Freeview Box" via your standard aerial, then you will NOT be picking up any Italian channels. I suggest you have a satellite STB which picks up the Freeview channels and many other "Free to Air" channels..
Stars
- London
- Posts 1,483
Yes that's right Keith, my Freeview box is connected to the satellite outside. Do the majority of Freeview users have an aerial instead of satellite?
Keith Saunders
- Posts 3,810
Henry, DVT-T means a MPEG decoder via the standard aerial. The "T" means Terrestrial DVB-S means a decoder via satellite
benoit
- Posts 124
"DVB-T is an MPEG-2 decoder which in the UK means Freeview." And in France after december 2008 it will necessary be Mpeg4. Will the BV8 have a Mpeg2 or Mpeg4 decoder? Pray... If someone knows?
PhilLondon
- London
- Posts 2,545
I think none of the B&O TV or Beosystem 3 has MPG4 yet. Am I right? p.
Kellogg
- Joined on 09-21-2007
- Posts 52
Hi, Will this only be available for BV8? Or will it also be available for BV6 and BV7? BR, Lars.
PhilLondon
- London
- Posts 2,545
BV6 and 7 are now sold with DVB-T module already, in most markets. p.
Keith Saunders
- Posts 3,810
There are two (2) current versions of DVB decoder namely the DVB-T and the DVB-T/S. These decoders only decode MPEG-2 which means not HD The DVB-T can be fitted to the following Beovisions:- - Avant DVD 32"
- BeoVision 3 32"
- BeoVision 5
- BeoCenter 6 26"
- BeoVision 6 26"
- Avant DVD 28"
- BeoVision 7 32"
- BeoVision 7 40"
The DVB-T unit which fits into the above Beovisions looks as follows:-
The DVB-T/S is a totally different unit and is a combined unit for satellite and standard aerial digital transmissions and is shown below. It is used in Beosystem 3, later Beovision 7's and Beovision 9's
The Stig - ver. 1.7
- Posts 898
Todays DVB-T module can show Mpeg4, with a cam module like this in SD.
Page 1 of 1 (24 items)
