Thanks Peter,
The 4500 CD player is an obvious match for my Beomaster 4500 and I could use the remote with it as it comes with the 7-pin DIN connection, unlike my CDX which has RCA plugs. (Works with my McIntosh setup, so the question is do I want a CD player with the 4500.)
The Beogram 4500 is with a re-seller on eBay, not usually the best senerio, as when they say it works great, that has little if any meaning.... becuase they don't really know.
The unit is close by (relitively) and very cheap.... two attractions at present. We'll see.
Thanks for the technical information!
Jeff
