Latest post 04-24-2008 5:02 PM by stefan. 3 replies.
Page 1 of 1 (4 items)
  • 04-24-2008 4:47 AM
    • Luigi
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Figueres (Spain)
    • Posts 3,013
    Beo5 and projector (problem)
    Hello,
    I have a problem with my Beo5 configuration, a strange problem I have never had.
    I have bought a projector (Panasonic PT-AX200E) and I want to create a button to control differents functions: down the projector screen(LC2+rele), switch off (slowly) the light (syncronicity with the screen), and select V.Aux of my BV3-32 (only sound).
    For this, I created the follow secuence: Cinema Button (with submenú: TV, DVD(BC2), V.Mem(Hdr2), V.Aux (PS3) and Camcorder )
    0:000:Light:Step_DW (x50)
    0:000:Light:Stop
    0:000:Radio: Aux_V
    This secuence worked fine, but when I entered in the submenu the hard buttons controlled the light.
    So, I tried to add:
    0:000: Light:Step_DW (x50) (down the screen and turn off the light in the same time)
    0:000:Light:Stop
    0:000:TV:Aux_V
    Delay 300ms
    0:000:Radio:Aux_V
    Some problems were solved, but I had others. The TV channels (logo) control the light, and the hard button of Beo5 (into submenu V.Mem) control de light, too. But the Beo5 configuration Tool show the corrects commands!
    For exemple:
    For TV channels of V.Tuner show:
    0:000:Radio:Ciffer_1+0:000:Radio:Play
    But this active the light!
    I have had to insert this:
    0:000:TV:Aux_V
    Delay 300ms
    0:000:Radio:Aux_V
    because I needed change from TV to DVD (or another devides) and the BV3 sent the image out to the projector. For this reason I added 0:000:TV:Aux_V before.
    I'm very worried. Anyone can help me?
    Regards.
    Luis
  • 04-24-2008 10:54 AM In reply to
    • stefan
    • Top 50 Contributor
    • 200 miles from Struer
    • Posts 1,733
    Re: Beo5 and projector (problem)
    Hi Luigi,
    seems like your Beo5 is in LIGHT mode, when you enter the cinema button`s submenu. I would try a cinema button as described but without submenu. Control TV, DVD.... as usual.
    Hope this helps.
    Stefan
  • 04-24-2008 12:18 PM In reply to
    • Luigi
    • Figueres (Spain)
    • Posts 3,013
    Hi Stefan,
    Thanks for your help.
    I think the same, but I don't know how I can take off this mode.
    This afternoon I have created a new cinema button, and I have copied and pasted the submenu buttons. Then, All the buttons work perfect. I suppose I will create a button into the cinema button to control the light.
    Regards.
    Luis
  • 04-24-2008 5:02 PM In reply to
    • stefan
    • Posts 1,733
    Hi Luigi,
    glad that you could solve the problem.
    Stefan
