*************************** LINK SYSTEM SETUP *************************
Master Control Link
X-tra TV
Beovision MX 4000 IT
Connection
Connect the MCL cable to the SPEAKERS 2 sockets on the audio
master in the central room.
If an MCL cable is already connected, connect the new cable in
parallel.
The aerial signal is distributed to the TV in the Link room from
the LINK output terminal on the BeoVision in the Central room.
Connect the AUDIO AUX LINK socket of the TV-set to the AUX socket of
the MCL 2AV using a 7/7-pin DIN cable.
Connect the mains adaptor to the DC 15V input of the MCL 2AV.
Setting of option on the LINK TV-set
BeoVision:
OPTION 2, with Beo4
Press: | Display:
STANDBY + LIST at the same time | OPTION?
GO | V.OPT
2 | Observe confirmation
| from the BeoVision
Note!
The modulator in the main room VTR cannot be used for
HF distribution.
After installation or a mains dropout the BeoLink Converter in the
main room must be configurated to MCL by selecting an Audio source
from a MCL local room.
The following frequencies is programmed from factory.
V.TAPE 1 P.nr. 60 599 MHz
SATELLITE
LINK TV
CDV
V.TAPE 2 P.nr. 61 567 MHz
It is not possible to switch on the source last listened to by
pressing MUTE on a remote control.
The MCL 2AV must be equipped with software (S/W) 2.1 or higher,
part no. 8341172.
No audio or video recording in the central room can be initiated from
the local room.
Stereo sound in the local room from the VTR in the central room can
obtained in two ways:
- Press: V.TAPE AV V.TAPE.
V.TAPE switches on the VTR in the central room,
and reproduces picture and mono sound in the local room.
AV V.TAPE reproduces a stereo sound in the local room.
- Select option 5 instead of option 6 (hardware option) by mounting
the jumper J1 in the MCL 2AV's microprocessor shield.
Stereo sound is automatically obtained when the VTR is switched on
(press V.TAPE).
The stereo sound is distributed by the audiomaster in the central
room. This means that the audiomaster cannot be used for other
purposes, e.g. playing radio in the central room or in another local
room while the stereo sound is being distributed.
********************* REMOTE CONTROL FOR LINK ROOM ********************
The recommended remote control is Beo4
Setup for Beo4 remote controle:
Beo4's "LIST" must contain the following items to be able
to operate the products from the Link Room.
CLOCK
LARGE REVEAL INDEX UDDATE MIX
LINK
CDV (only with S/W lower than 4.0 in Beo4)
V.SETUP (only with S/W 2.0 or higher in Beo4)
AV (only with S/W 4.0 or higher in Beo4)
See Beo4's operation manual page 10/12 on REMOVE and ADD functions
from/to the List
