I have a B&O 2400 and B&O speakers. Both speakers seem to be ok, but cannot get both to play at the same time. The"Balance slide" does not seem to allow alternation from one speaker to the other. Any ideas? Do you think that there is a problem with the 2400 or or is it some switch or wire that is loose? Any advise will be appreciated. Donald
