1st March February 2012
Latest post 04-13-2008 10:55 AM by Dillen. 6 replies.
04-12-2008 1:08 PM
richtoy
![](/utility/anonymous.gif)
![Top 500 Contributor Top 500 Contributor](/Themes/beotheme1/images/rankicons/rankTop500.gif)
![Male Male](/Themes/beotheme1/images/rankicons/GenderMale.gif)
- Joined on 09-20-2007
- Valkenburg, Netherlands
- Posts 184
![Gold Member](/Themes/beotheme1/images/roleicons/d27431af-8474-494c-aeb0-d1cede4cb008.gif)
Switch unit (specifically just the internals of the FM switch) for a BM2200 (type 1601)
Hi Does anybody have one of these they don't need? The FM switch has obviously been dismantled in the past and whoever put it back together broke the tiny metal contact mechanism when reassembling so a repair is not possible ![Angry](http://forum.beoworld.org/emoticons/12.gif) Regards Richard
Some of my B&O: BV3/32, MX7000, MX5500, LX5500, MX4000, BM8000, BM6000, Overture, BL8000, BM6000 Quad, BM4400, BM3400, BG-CDX, BM3000, BM1001, BM1200, BM1600, BM1700, BM1500, BM1400, BM2400, BM2300, BM4500, BM4000, BVM70, BVS45-2, BVS60, BC7700, BM2200, BM1900, BG8002, BM1202, BVPenta, BVP45
Dillen
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.00.21.31/avatar.jpg)
![Top 10 Contributor Top 10 Contributor](/Themes/beotheme1/images/rankicons/rankTop10.gif)
- Joined on 02-14-2007
- Copenhagen / Denmark
- Posts 5,008
![Founder](/Themes/beotheme1/images/roleicons/6f51347a-6d4c-4ff4-9d2e-4e3705076d55.gif)
Re: Switch unit (specifically just the internals of the FM switch) for a BM2200 (type 1601)
Is that the one in the dual-row switch bank ? Martin
richtoy
- Posts 184
Yes Martin, the rightmost switch on the bottom row. After changing all the caps I got beautiful sound from the tape/phono and the am section of the tuner but no FM. After 30 minutes with the multimeter I found that the FM switch was open circuit, I tried cleaning it but it made no difference so I carefully took it out. You can then clearly see that half of the contact is missing on both sides. When I then short the contact the FM section bursts into life and for the other side of the switch, the FM section of the light illuminates. Richard
Dillen
- Posts 5,008
Oh, so all that's missing is the two tiny bronze contact sliders inside the switch ? I will look for some. Martin
Dillen
- Posts 5,008
I have a complete FM switch. On it's way to you ! Martin
richtoy
- Posts 184
Thanks Martin ![Big Smile](http://forum.beoworld.org/emoticons/02.gif) The sound of the BM2200 is quite outstanding. Rich bass and very controlled, even at high volume. I think I will keep it for my office/workshop together with a couple of S45.2 speakers ... Richard
Dillen
- Posts 5,008
Yes, the old Beomaster 2000 and 2200 have wonderful sounding amplifiers. I would prefer them to any newer hybrid amp anytime. Martin
Page 1 of 1 (7 items)
