Latest post 04-02-2008 12:42 PM by beocool. 11 replies.
Page 1 of 1 (12 items)
  • 04-01-2008 9:44 PM
    Beocenter 9300
    Dear All:
    I have the opportunity to purchase a Beocenter 9300 for about $700 US dollars in mint condition.  Comparing to the 9500, which do you like best.
    Also, how would I connect it to the current set up: BV 7, BS 9000 masterlinked to BV 7, speaker BL 9, BL 3?
    Thank you for your help.
    Dario
    When I hear music, I fear no danger. I see no foe... Thoreau
    Filed under:
  • 04-02-2008 1:41 AM In reply to
    • Christian
    • Top 100 Contributor
    • Joined on 04-16-2007
    • Copenhagen, Denmark
    • Posts 626
    Re: Beocenter 9300
    I your case, where you do not need an amplifier, I would go for the 9300. The 9300 is almost the same as an Ouverture, and best suited for active speakers.
    Living room: BV7-40 mkIV + V8000, BL5, BL3, BM1 and BS9000. Bedroom: MX3000 and BL4500 on MCL2-AV. Around: PentaIII, CX100 and MCX35 on ML/MCL + MCL2-A, BeoPort and BL4 on ML, BS3300 + M75 as stand alone, BC6000 + BC600 and BT1100, LC1, LC2, Beo4, Beo5 and BL1000, BS2 and A8, EarSet2, Apron, Coffee mugs, Enamel Bagdes, Bath towel, Keyring, Books, Lots of miniature and the Bottle opener. Office: BC2300 + BL2500 and BS3. Summer house: BS Century.
    Addicted? Oh no.... ;)
  • 04-02-2008 2:17 AM In reply to
    Re: Beocenter 9300
    Great piece...it's a personal issue... i like the shiny 9500...the 9300 is brushed alum.....
    You can actually use a switch made by one of the members here...that will allow you to switch between 2 masters and go out to the same speakers....very cool item...
  • 04-02-2008 2:30 AM In reply to
    Re: Beocenter 9300
    You could also use a Russound speaker switch which you can see HERE
    Regards Keith....
  • 04-02-2008 2:34 AM In reply to
    • Christian
    • Posts 626
    Re: Beocenter 9300
    I am almost sure that the 9300 also was made in shiny steel, but you can't always pick and choose in the second hand market. Smile
  • 04-02-2008 3:29 AM In reply to
    • rfc1
    • Top 500 Contributor
    • Joined on 02-06-2008
    • Posts 166
    • Gold Member
    Re: Beocenter 9300
    Keith Saunders:
    Does that russound switch have the ability to plug in a pair of powerlink active speakers ?
    sandy
  • 04-02-2008 3:43 AM In reply to
    Re: Beocenter 9300
    Frank Rizzo:
    Incorrect I'm afraid. Most 9300 are polished, just like the 9500, None of them are brushed but the very latest 9300 were MATT rather than brushed. This change seems to coincide with the change to the CDM Pro linear cd mech although I can't guarantee that.
    I would favour the 9300 as it's a later model and a large number of spares are still available.
    Regards Graham
  • 04-02-2008 3:56 AM In reply to
    Re: Beocenter 9300
    ahhh...thanks Graham....i've seen probably 3 of the 9300's and they were all the Matt...as you say...which looks brushed to me....so good info....
  • 04-02-2008 4:12 AM In reply to
    Re: Beocenter 9300
    Compare the matt to the panels on a 9000 and you will see the difference.
    Regards Graham
  • 04-02-2008 4:50 AM In reply to
    Re: Beocenter 9300
    Isn't the 9300 one-way IR only? If it is, then you might want to go for a two-way 9500, assuming you like the possibility of using a Beolink 5000 or 7000 (I know I would - the 7000 in particular is so cool it is untrue!)
  • 04-02-2008 4:55 AM In reply to
    Re: Beocenter 9300
    Sandy,
    The Russound switch can only be used for switching speakers meaning passive speakers, so no it cannot switch active Powerlink speakers.
    Regards Keith....
  • 04-02-2008 12:42 PM In reply to
    Re: Beocenter 9300
    j0hnbarker:
    Yes, the 9300 has one-way IR only. Mine has the shiny aluminium panels, by the way.
