Latest post 04-04-2008 12:15 PM by Medogsfat. 3 replies.
Page 1 of 1 (4 items)
  • 04-01-2008 2:25 AM
    Looking for Removable Datalink Pins
    I have a Beocord 3300 and Beogram 3300 which don't have the extra two pins used for Datalink. Does anyone know of a source for these screw-in pins, or some good workaround?
    Thanks,
    John
  • 04-01-2008 3:15 AM In reply to
    Re: Looking for Removable Datalink Pins
    Remember that each device actually only needs one pin. Martin has made some from brass - they are not cheap to make though!
  • 04-01-2008 9:32 PM In reply to
    So the data ground is not necessary then? Where can I contact Martin regarding pins? Thanks!
  • 04-04-2008 12:15 PM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    Martin is Beoworld member Dillen and you will find him answering questions in the Beogram/workbench & vintage sections mostly.
    Chris.
