Latest post 04-01-2008 3:07 AM by Keith Saunders. 5 replies.
Page 1 of 1 (6 items)
  • 03-31-2008 5:43 PM
    beosound 3000 and N Music
    Hi there
     I have a load of music on my PC that I would like to be able to play through my beosound 3000. I understand that I will need more than just a cable, I see I will need the 'beolink pc2' - can anyone tell me how much this costs / what is a fair price for it? I understand I will also need a cable as to my knowledge there is no way to do it wirelessly?
     Also, does it use the masterlink socket on the bs3000? I have already used the AUX-5 pin din, so that wouldnt be an option
     I already have the beoplayer software installed..
     Any information greatly appreciated
     Chopper
  • 03-31-2008 6:00 PM In reply to
    Re: beosound 3000 and N Music
    From memory - as I sold this system a couple of years ago!
    You need a Beolink PC2 which was renamed as Beoport. This connects to your computer with USB cable and to the 3000 via Masterlink. Comes with a software on CD but you can download the latest version from the B&O website.
    Suggest that you look on eBay for local prices.
    Regards Graham
  • 03-31-2008 6:11 PM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    joeyboygolf:
    Good memory Graham, there is also a lead from the sound card on your PC that goes to the PC2/Beoport.
    CraigSmile
  • 03-31-2008 6:13 PM In reply to
    Make sure you have the latest software in your BS3000.
    If it has the large CD-clamper it's no problem but if you have small one you might have to do a small SW upgrade.
    /Ola
  • 04-01-2008 2:53 AM In reply to
    • Silou
    • Top 500 Contributor
    • Joined on 08-10-2007
    • Switzerland
    • Posts 241
    • Gold Member
    Any upgrade exist for the Ouverture?
  • 04-01-2008 3:07 AM In reply to
    Sorry, there is only software updates for the Beosound 9000 and the Beosound 3000 to allow them to support N.Music.
    The Ouverture does not have a software update to provide the N.Music functionality.
    Regards Keith....
