Latest post 05-05-2007 9:54 AM by Rasmus. 2 replies.
Page 1 of 1 (3 items)
  • 05-03-2007 2:19 PM
    • Rasmus
    • Not Ranked
    • Joined on 04-24-2007
    • Aalborg, Denmark
    • Posts 9
    BeoGram 9500 Record Deck
     I can't find any information about RIAA and the BeoGram 9500... Is it build in or not?
    The reason for asking is that I'm designing a switch-box with inputs from BeoGram 9500 and BeoVision LS4500 and output to BeoSound 4, so I have to know if I have to build in a RIAA amplifier or not...
    Also - the pinouts in the DIN plug from the BeoGram 9500 - please post them here... :-)
    Best regards, Rasmus M. Jensen
  • 05-03-2007 8:44 PM In reply to
    Re: BeoGram 9500 Record Deck
    The BeoGram 9500 does not have RIAA, it used the RIAA amp in the BeoCenter 9500. If you want to attach a record deck to an AUX port, it will need the RIAA amp built into it (the Beogram 4500 does, and looks like the BG 9500).
    Circuit diagram: all you want to know is here: http://www.beotech.co.uk/
    Hope that helps!
  • 05-05-2007 9:54 AM In reply to
    • Rasmus
    • Not Ranked
    • Aalborg, Denmark
    • Posts 9
    great... looks good.
    I'll build the RIAA myself - it's much cheaper than buying a BG4500 Big Smile
     thanks!
