Latest post 03-26-2008 6:27 PM by The Stig - ver. 1.7. 9 replies.
Page 1 of 1 (10 items)
  • 03-25-2008 2:15 PM
    • Bieele
    • Top 200 Contributor
    • Joined on 04-16-2007
    • Netherlands
    • Posts 339
    Beolab 3500 powerlink?
    On the B&O site I noticed in the specifications of the Beolink Wireless 1 the following sentence:
    "We have also updated the beolab 3500, giving it a power link socket, whick makes it compatable with beolink wireless 1".
    On the specification page of the beolab 3500 I could not find this info (they do mention a W1 link, that might be a powerlink?), therefore 3 questions:
    - Is it correct that the latest version of the beolab 3500 is equipped with a powerlink socket?
    - If yes: Would this also mean that the beolab 3500 can be used as center speaker?
    - If yes: How well would the beolab 3500 in a 5.1 setup together with 2xBL1, BL2 and 2xBL4000 (compared to a BL7.1)?
    Thanks for your info!
    Bieele
    BTW: A dealer told me yesterday that I can not order 1 BL3, is this correct? Are there smart ways to order 1 BL3?
    Heej zuij der alles veur gaeve En heej zaet ze mogen ut hebbe van meej
  • 03-25-2008 2:39 PM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Re: Beolab 3500 powerlink?
    There was a company that could modify a Beolab3500 for use a centre speaker in a 5.1 setup. Pretty sure they were based somewher in France. maybe someone has a link.
    CraigSmile
  • 03-25-2008 2:48 PM In reply to
    • Stan
    • Top 150 Contributor
    • Joined on 04-17-2007
    • Posts 593
    • Gold Member
    The latest BL3500 does have a powerlink socket.  However, it's still a 2 channel speaker, and the center speaker is a single channel.  I suppose you could customize a cable to send the one center channel down both L and R of the powerlink.
    Stan
  • 03-25-2008 2:53 PM In reply to
    I've not used them, but here's the link to the French company mentioned above.
  • 03-25-2008 2:57 PM In reply to
    • Craig
    • Posts 4,855
    beo-ap:
    Thats the one, I knew someone would be able to post a link.
    CraigSmile
  • 03-25-2008 5:11 PM In reply to
    • Bieele
    • Netherlands
    • Posts 339
    Stan:
    Stan
    I am aware of the French company to connect it; but would like to know if this is still needed since there is already a powerlink available.
    Stan, Could you clarify this. I would expect this cable change to be quite easy (just make sure the left and right signal are equal?
    Also I am curious about the expectations about sound quality.
    Bieele
  • 03-25-2008 5:16 PM In reply to
    • Alex
    • Top 25 Contributor
    • Bath & Cardiff, UK
    • Posts 2,990
    Stan:
    Stan
    The 'BeoLab 7-1' or '7-2' setting should send sound down both left and right of the PL.
     Weekly top artists:
  • 03-25-2008 5:47 PM In reply to
    Alex:
    Stan:
    Stan
    There is no issues with L-R, instead there is an big issue in the sound the BL3500 can reproduce. BL3500 is like BL6000  and BL 7-1/2 is like BL9. the problem is that the TV sends the low freq. sound to does speakers in the surround setup thats can reproduce them. BL 7 can BL3500 can NOT, but on BV7 and BS3 you can choose BL6000 as center speaker wish is the best choice if not BL4 is even better.
    To demonstrated this:
    If you have a BV7 and a BL2, then set your front speaker to BL5 and see haw BL2 stops playing.
  • 03-25-2008 8:23 PM In reply to
    I love the BL3500. I think it is a great B&O design statement. I listen to mine almost every day - morning radio. However, I must agree with The Stig: BL 3500 would no be my choice for a center channel from a sound point of view. If aesthetics is what you want, then it's ok.
    I would also choose the 4000's for a center channel. Before B&O had dedicated center channels this was the specified speaker. Two 4000's will blow a 3500 away any day.
    I have also seen, though not heard a single 6000 as a center channel. Once upon a time, my dealer in Tysons Corner was able to fit an cap on the end of the 6000 where the stand goes. I don't actually remember how the 6000 was suspended to the wall.
    To my ear, a single 6000 sounds better than a 3500. Is it just me?
    The new center channel speakers are great performers, but design wise they just don't do it for me.
  • 03-26-2008 6:27 PM In reply to
    beo-ap:
    I have seen and heard a center BL6000 mounted on the wall bracket from a BL3500, very disappointing flat sound. Think BL3500 will do a better job.
