Latest post 03-24-2008 2:21 PM by colin. 2 replies.
Page 1 of 1 (3 items)
  • 03-22-2008 7:25 AM
    • colin
    • Not Ranked
    • Joined on 03-22-2008
    • Posts 2
    BEOMASTER 6500/BEOLINK 1000
    Can someone help me?  I have the above equipment but have mislaid the Beolink 1000 manual.  I need to reset the frequency of some radio channels that were programmed in when the equipment was reinstalled.  I have no idea what sequence of keys etc to press.
    Thanks  very much
    Colin
  • 03-22-2008 7:40 AM In reply to
    Re: BEOMASTER 6500/BEOLINK 1000
    Much easier with the MCP or Beolink 7000. However it is possible - press go to and then use the >> and << keys to go to the program you want. Then press store, the number you want the channel stored as and then store again.
  • 03-24-2008 2:21 PM In reply to
    • colin
    • Not Ranked
    • Posts 2
    Thanks, Peter.  It seems to have worked fine.
