Latest post 03-23-2008 4:56 AM by KingStreet. 5 replies.
Page 1 of 1 (6 items)
  • 03-21-2008 8:22 PM
    MX4000 / DVD1 & new sky + box
    Hi
    I have just signed up today for sky+, due to be fitted next week sometime. Could anyone help me go through the set up needed to get everything working together with the beo4 remote properly? or do I get the sky fitter do this - I guess not?
     thanks in advance
     p
  • 03-22-2008 4:49 AM In reply to
    Re: MX4000 / DVD1 & new sky + box
    Have you got the STB-C fitted to the MX4000? Are you using Sky at present? There may be a software requirement as the older STB-Cs did not cover Sky+. The code for a Sky+ box is 16.
  • 03-22-2008 8:18 AM In reply to
    No, I haven'y got sky at present, just the 1-5 channels, and to my knowledge I don't have the set top box contol fitted - is there anything I could do?
  • 03-22-2008 8:46 AM In reply to
    Tricky! You need the STB-C kit and from experience, these are no longer made. If you are lucky, and have a good dealer, he might track one down for you. The kit is about £100 and there will be a fitting charge as well. Clearly if you get one, it will have the most recent software and will work with Sky+.
    Sky+ is quite frankly fantastic and I recommend it whole heartedly. I am not a fan of the Murdoch empire, but it really is much better than the alternative in my experience. Get a Pace box though - the Amstrad ones are unreliable and the power supplies marginal. They also tick all the time. I changed by buying a new Pace and it is fantastic. Integrates with my Avant just as if it were made by B&O. Except better!
  • 03-22-2008 3:44 PM In reply to
    Thanks Peter
    I will look into this, although I am trying to sell myself on the Beocentre6-26 instead of the MX!
    The sky+ comes with a box though doesn't it? do I have to purchase another STB box?
     thanks
    P
  • 03-23-2008 4:56 AM In reply to
    Peter is correct ( again !!)
     The STB he refers to is a control system that allows the B&O product to control your digibox.  standard on later MX's, most Avant variants, and all panel TV's.
    If your considering a new Bcen 6, then I suggest you contact your local dealer - put these questions to him/her, and you should be sorted - wether you get a new TV or modify your exisiting one. - BTW - not all MX TV's can control digiboxes, although all are compatible ( despite the digital switch over scaremongers) - you would just end up using the SKY supplied remote if your MX is older.
    Bang & Olufsen of King Street - Manchester,UK. SKYPE - beokingstreet
