I wouldn't recommend the 2200 really.
It is not remote control and is in fact a Japanese music centre. I would strongly suggest you look elsewhere - Think about a Beocenter 9500 if can afford one, or maybe something like a Beocenter 7700 if you cannot. Both of these are far superior to the 2200.
The Beovox X25 is not a speaker I would really recommend either. Look for the S45-2 which can be about the same price and are much better!
