Latest post 03-09-2008 7:44 AM by Ian. 1 replies.
Page 1 of 1 (2 items)
  • 03-09-2008 5:28 AM
    B&O 2400 or 2500
    hi what is the difference between these 2 phones and will they both work with broadband if i use a filter?
    thanks
  • 03-09-2008 7:44 AM In reply to
    • Ian
    • Top 500 Contributor
    • Joined on 04-16-2007
    • UK
    • Posts 132
    Re: B&O 2400 or 2500
    The 2500 has callerID, and the 2400 doesn't. I have a 2500 and broadband and it works fine (with a filter)
    Ian
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
