Latest post 03-09-2008 2:43 PM by Fil. 4 replies.
Page 1 of 1 (5 items)
  • 03-08-2008 9:05 AM
    • Fil
    • Top 500 Contributor
    • Joined on 04-17-2007
    • Posts 90
    BV3 and masterlink
    Hi everyone.
    Just a quick one..................does the BV3 32" come standard with masterlink? (do all sets have it)?
    Thanks in advance
    Fil
  • 03-08-2008 10:52 AM In reply to
    • Opman
    • Top 200 Contributor
    • Joined on 12-31-2007
    • Cheshire, UK
    • Posts 323
    Re: BV3 and masterlink
    Hello Fil
    Yes, The BeoVision3 32" DOES have Masterlink as standard. I think that on some of the early 28" versions it was an optional extra. The 32" version is the same chassis as the Avant and ALL avants have Masterlink. The 28" BeoVision3 is the same chassis as Bcen1.
    Of the current range of televisions, all have Masterlink EXCEPT BeoVision8. You have to order a "Sytem module" if you want to incorporate BeoVision8 into a link set up.
    Opman
  • 03-09-2008 6:39 AM In reply to
    • Fil
    • Posts 90
    Thanks for your quick response.
    Is there anyone else that could just confirm this for me?
    Fil
  • 03-09-2008 7:52 AM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    My BV3-32 which is a 2004 model has Masterlink fitted. As previously said i think it was the 28" where it was a additional modual. One of the reasons the 28" version was not so popular as the 32" was that by the time you had brought all the extras there was little difference in price.
    CraigSmile
  • 03-09-2008 2:43 PM In reply to
    • Fil
    • Posts 90
    thanks for your help guys!!
