Latest post 03-11-2008 2:33 PM by SWISS_2. 7 replies.
Page 1 of 1 (8 items)
  • 03-05-2008 11:09 PM
    US vs. European Version of Beocom 6000
    Does anyone know if a Beocom 6000 purchased in the UK will work in the US, assuming you get the correct charger?  Question is in reference to frequency and compatibility with US versions of the phone.
    I currently own 2 x US version Beocom 6000s (predecessor to the Beocom 1) and would like to add a third phone.
    Thanks,
    Brian
  • 03-07-2008 3:07 PM In reply to
    • Russ
    • Top 100 Contributor
    • Joined on 05-07-2007
    • Washington, DC USA
    • Posts 641
    Re: US vs. European Version of Beocom 6000
    That won't work.  The US spec phones are 2.4gHz, the Euro phones are 1.9gHz.
    Russ
    We kid because we love.
    Bang & Olufsen Tysons Galleria
    McLean, VA USA
  • 03-09-2008 11:21 AM In reply to
    • Jandyt
    • Top 10 Contributor
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    Are you sure about that, Russ?
    I think they are all 2.4Ghz but there is some other issue why UK ones wont work in USA.
    Andy T.
    Poor me, never win owt!
  • 03-10-2008 12:13 PM In reply to
    • Russ
    • Posts 641
    Jandyt:
    Andy T.
    Pretty sure Andy, the UK specsheet indicates the DECT system.
    Russ
    McLean, VA USA
    • Russ
    • Posts 641
    Jandyt:
    Andy T.
    Russ
    McLean, VA USA
  • 03-11-2008 1:26 AM In reply to
    • SWISS_2
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Neuchatel, Suisse
    • Posts 552
    • Gold Member
    RussR is correct: UK-US models = Different systems.
    A German BC 6000 will work, providing a power (mains) converter is used to step up the power to 200-240 v from the US 110 v. I brought a few over years ago from Germany, and later gave them to friends in North America. To my knowledge, both units continue to work well there.
  • 03-11-2008 2:24 PM In reply to
    • Russ
    • Posts 641
    Thank you Swiss,
     and now I'm going to disagree with you too. Stick out tongue
    In so far as you gave your friends complete systems, and they used transformers to convert power, I will agree that that may well work (even in the UK), the original question here involved mixing handsets from the UK with handsets from the US.  That won't work, regardless of how many transformers you add.
    Russ
    McLean, VA USA
  • 03-11-2008 2:33 PM In reply to
    • SWISS_2
    • Neuchatel, Suisse
    • Posts 552
    • Gold Member
    OK. To clarify ( Back to the original question ) : Different telephone systems between US & UK do not work.
