Latest post 03-03-2008 5:57 PM by Craig. 14 replies.
Page 1 of 1 (15 items)
  • 03-01-2008 2:31 PM
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Beomaster 2400 - No sound.
    Well the title of the thread says it all really. It powers up but there is no sound. Connected an FM aeriel and from the tuning lights it seems to be picking up stations ok. When you try to adjust the volume the light on the right side gets slowly brighter, but then it suddenly goes back again. If that makes sense?
    CraigSmile
  • 03-02-2008 12:26 PM In reply to
    • Dillen
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Beomaster 2400 - No sound.
    It makes sense alright.
    You will probably find the lamp inside the LDR housing burned.
    The lamp regulates the volume through the LDR's in a way so that less light gives higher volume.
    Fortunately, a clever little circuit mutes the amp inputs if the lamp draws no current (burned filament), otherwise it would give max volume constantly.
  • 03-02-2008 12:29 PM In reply to
    • Craig
    • Posts 4,855
    So it could be down to just a blown bulb then? both the left and right bulbs on the volume do light up. Although the one for the Trebel does not. What does LDR stand for?
    CraigSmile
  • 03-02-2008 12:50 PM In reply to
    Light Dependent Resistor?
  • 03-02-2008 1:43 PM In reply to
    • Craig
    • Posts 4,855
    Peter :
    Thanks Peter.Embarrassed
    CraigSmile
  • 03-02-2008 3:56 PM In reply to
    • Dillen
    • Posts 5,008
    Exactly !
    There are four of them housed in a little metal shielding together with a lamp.
    Two for each channel (volume and loudness).
  • 03-02-2008 4:24 PM In reply to
    • Craig
    • Posts 4,855
    Martin, I can find two bulbs for the volume. these are in one section that is held in by two screws. Then there is a similar section which houses threee bulbs, for the Balance, Treble & Bass. All the bulbs are solder in place. or have I missed another set of bulbs?
    CraigSmile
  • 03-02-2008 4:28 PM In reply to
    I think you are looking for a white sealed box. The bulbs are in there.
  • 03-02-2008 4:49 PM In reply to
    • Craig
    • Posts 4,855
    Thats what I have found two of. As I say one has two bulbs in it the other has three. On both there is a small PCB which has the bulbs on. Nowhere can I find one with four as Martin mentions.
    CraigSmile
  • 03-02-2008 5:09 PM In reply to
    • Dillen
    • Posts 5,008
    You will find it on the large main board, lift away the tonecontrol board and look for a little metal box, apprx 25mm square.
    You can't see the light from the lamp, it's shielded to keep ambient light out or it would mess up the volume.
    You can see it here (main board shown without the plastic frames etc.)
  • 03-03-2008 1:45 PM In reply to
    • Craig
    • Posts 4,855
    Thanks for the picture Martin it helped a lot. So I have now found the box which houses the lamps. How do I get inside it? Don't want to go breaking anything else. What I have noticed is the box sits on a small PCB which is soldered to the main PCB. The box is very loose on the small PCB. Should it be like this? Tried to pull it up gently but did not want to use to much force.
    CraigSmile
  • 03-03-2008 4:15 PM In reply to
    • Dillen
    • Posts 5,008
    You can solder out the box for an easier handling but you will have to use a little "controlled force" to open it.
    Put an ohm-meter to the lamp first to confirm the diagnose first.
  • 03-03-2008 5:27 PM In reply to
    • Craig
    • Posts 4,855
    Well I tried to open the top of the box with it in place. Bad idea, I now have 4 broken LDR's. Are these all the same or do they vary in resistence? If they are standard I can just replace the old ones and the bulb at the same time.
    CraigSmile
  • 03-03-2008 5:46 PM In reply to
    • Dillen
    • Posts 5,008
    Oh,
    I think they are of the same value but I'm not 100% sure. If everything else fails I may be able to help you find a complete and working part but let's first know if the lamp was burned. Laughing
  • 03-03-2008 5:57 PM In reply to
    • Craig
    • Posts 4,855
    That would be the lamp that is now shatteredLaughingWell I did find these LDR'S on the web.
    CraigSmile
