Latest post 05-04-2007 5:21 AM by Beowulf. 4 replies.
Page 1 of 1 (5 items)
  • 05-01-2007 7:17 AM
    • Beowulf
    • Top 500 Contributor
    • Joined on 04-16-2007
    • Derbyshire
    • Posts 143
    Is it possible to connect an i pod via the aux input on MX7000?
    Regards
    Dave
    Beowulf
  • 05-01-2007 7:32 AM In reply to
    • beoaus
    • Top 150 Contributor
    • Melbourne, Australia
    • Posts 445
    Re: Is it possible to connect an i pod via the aux input on MX7000?
    In theory the Audio AUX Link should support it. I think that is how my BS9000 was connected originally, its a while ago now.
    You could use a Scart to RCA converter.  With some smarts you can set it up so that the TV and speakers turn on with the IPod.
    beoaus.
  • 05-01-2007 8:23 AM In reply to
    • Beowulf
    • Derbyshire
    • Posts 143
    Thanks for your reply beohaus, i was thinking of using a seven pin din connecter to stereo jack via the aux audio input this would leave my 2nd scart free
    Beowulf
  • 05-03-2007 9:36 AM In reply to
    absolutely... you need a 5 pin to mini-jack cable. You then just press av then cd on your remote and the sound comes out of the active speakers. i had this set up until i got my bv3. now i have to run it thruogh a beolink converter then through the masterlink socket. Works a treat!!
    My B&O: 2009 Catalogue and Pricelist
  • 05-04-2007 5:21 AM In reply to
    • Beowulf
    • Derbyshire
    • Posts 143
    Thanks for the responses and advice!
    Cheers
    Dave
    Beowulf
