I have recently restored my house and then I installed a Lexcom home system, with their own B&Q Master link module. The guys that installed the network has measured the network and it works as it should be. After that I bought B&O stuff, which I always have dreamt about. It looks like this:
TV room
Beocenter 2 connected to a surround amp thru RGB cables. My TV (Sony) is connected to the Amp and I have installed 5 Beovox 1 in the ceiling. I have also installed a inwall sub and that is connected to the amp as well. I really like the sound and the picture when I'm using the Beocenter 2 together with the rest of the stuff.
Bathroom
Beovox 1 connected to Beolink Active (placed in basement where I have the Lexcom patch panel).
Bedroom
Dining room
Beolab 3500
My big issue in this is that, when I try to connect my Beolab 3500 and the two other rooms I don't get it to work at all. It seems like it is the connection to the Beocenter 2 that fails. I have the option A.option 1 at the Beocenter 2 and L.Option 6 at the rest of the places. I have tried to connect one unit (Tried both Beolab 3500 and Beovox1) to the patch number that comes directly from the Beocenter 2, but that didn't seem to work either. The unit itself (Beocenter 2) works, since I can run DVD and CD, but it doesn't comes out to the other linked rooms.
Have anyone of you any idea of why this isn't working? It's getting really frustating since this is something that I have looked forward since the day we started to renovate our house. Appricates any help in this!!
