Latest post 11-03-2011 4:26 PM by Dillen. 4 replies.
Page 1 of 1 (5 items)
  • 02-13-2008 2:18 PM
    Misc. Beocord Problems - 3300, 5500
    Hi All - I am trying to get some old Beocord units working. Here's my problems:
    1) Beocord 5500 - everything works except the drawer in/out. One unit will go in slowly after a little encouragment but will not open at all.  The second won't do either.  Belts?  Also - how do you get access to belts, etc. for replecement (how does drawer come apart)?
    2) Beocord 3300 - Was working fine when stored 2 years ago. Now, unit powers up but heads & tape will not move.  When pushing play or forward/rewind buttons, unit tries to do something (clicks) for a second or two, then goes back to stop.
    Any help greatly appreciated.
  • 02-13-2008 5:04 PM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Misc. Beocord Problems - 3300, 5500
    Welcome to Beoworld and thanks for signing up as a silver member, thereby supporting us all !  Yes -  thumbs up
    Your Beocords are in need of new belts.
    The 3300 is fairly easy, I can supply the belts and mounting instructions.
    If a tape is stuck in the deck, don't force anything. The instructions will tell you how to get it out without damaging neither the tape nor the deck.
    The 5500 is a bit harder since more than one type of autoreverse deck was used in production.
    The drawer belt should be no problem though.
    In short; Remove the top cover, unscrew and lift up the large circuit
    board and you will have access to the drawer motor/belt.
    As a silver member you have access to service manuals and other goodies from the
    download section. Smile
  • 02-14-2008 5:26 PM In reply to
    Thanks for the info, Martin.  I will work on the three units this weekend and get a better idea of what is going on.  I will post back here with more details.
     Thnaks again - Dwight
  • 11-03-2011 3:37 PM In reply to
    • Doug
    • Not Ranked
    • Joined on 10-25-2011
    • Canada
    • Posts 6
    • Gold Member
    Hi Martin, I am interested in belts for my Beocord 3300. I took it apart and the belts all need replacement. Instructions on removing the  belts would be appreciated.
    Please contact me at your convenience.
    Doug
  • 11-03-2011 4:26 PM In reply to
    • Dillen
    • Posts 5,008
    I can help you with belts and mounting instructions for your Beocord.
