Does anyone have an original BEOTALK 1200 container that has the bar code sticker on it? If so, can you tell me the 12 digit number that is on the bar code sticker. Their are two numbers on each side of the code lines and ten numbers in two groups of five under the code lines. That makes up the UPC number that I need for inventory purposes. Thanks !!!
