Latest post 02-05-2008 12:12 PM by Keith Saunders. 1 replies.
Page 1 of 1 (2 items)
  • 02-05-2008 8:24 AM
    Can someone explain serialization errors
    Some time ago I received the configuration file of my BEO5. Now I have changed some icons. Just to see what is happening.
    When I choose voor downloading the configuration, there are some errors. I can't find anything in the help.
    It give me multiple SCENE buttons messages with ID-numbers. Nice, but with button is it???
    Below the message file:
    Serialization started ...
    Parsing beo 4 config ...
    Beo 4 configuration parsed. Nr of buttons =996. Time elapsed (ms) =750
    Parsing beo 5 config ...
    ERROR: [2522] "ZONES\WOONKAMER\AVANT\GENERICV.MEM\PANDP\DVD\SWAP" source_item  ABSD secondary target "ZONES\WOONKAMER\AVANT\DVD\PANDP\GENERICV.MEM" not found
    ERROR: [2115] "ZONES\WOONKAMER\AVANT\TV\AV\GENERICV.MEM\PANDP\DVD\SWAP" source_item  ABSD secondary target "ZONES\WOONKAMER\AVANT\DVD\PANDP\GENERICV.MEM" not found
    ERROR: [1780] "ZONES\WOONKAMER\AVANT\TV\AV\TV\PANDP\DVD\SWAP" source_item  ABSD secondary target "ZONES\WOONKAMER\AVANT\DVD\PANDP\TV" not found
    ERROR: [2186] "ZONES\WOONKAMER\AVANT\TV\PANDP\DVD\SWAP" source_item  ABSD secondary target "ZONES\WOONKAMER\AVANT\DVD\PANDP\TV" not found
    Beo 5 configuration parsed. Nr of buttons =6052. Time elapsed (ms) =3484
     Checking buttons ...
    ERROR:"",id=3049 has multiple SCENE buttons:<1094><3030>
    ERROR:"",id=3052 has multiple SCENE buttons:<1094><3030>
    ERROR:"",id=4771 has multiple SCENE buttons:<3833><4754>
    ERROR:"",id=4774 has multiple SCENE buttons:<3833><4754>
    Deleting unused images ...
    15 image(s) of 64 images deleted
    Unused imaged deleted.
       Time elapsed (ms) =0
    Serializing configuration ...
    Configuration serialized.
       Nr of bytes serialized = 1221844(~1193 Kbytes)
       Time elapsed (ms) =531
    Creating the configuration file ...
    Configuration file created
       Time elapsed (ms)= 1688
    Serialization done.
     Total elapsed time(ms) = 6531(~6,531 s )
    DONE but errors occured during serialization.Better not to use this configuration
  • 02-05-2008 12:12 PM In reply to
    Re: Can someone explain serialization errors
    Your problem is related to PandP where the tool does not handle it correctly.
    Please send me your configuration file called "Configuration.xml" and I will look at it.
    I will send you a PM with my e-mail address so you can send it to me as an attachment.
    Regards Keith....
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
