Latest post 02-01-2008 7:16 PM by Peter. 1 replies.
Page 1 of 1 (2 items)
  • 02-01-2008 6:42 PM
    • banner
    • Not Ranked
    • Joined on 01-27-2008
    • Posts 1
    • Silver Member
    Beocord 5000 5 pin DIN plug?
    I've just bought a Beomaster 5000 and a Beocord 5000 from a couple of different sources.  The beocord 5000 only has 5 pins in its DIN plug and isn't being controlled by the Beomaster 5000.  The cable is hardwired into the Beocord 5000, but I was expecting a 7 pin plug.
     Is the plug wrong or is there something else that I can check?
    John
    Filed under:
  • 02-01-2008 7:16 PM In reply to
    Re: Beocord 5000 5 pin DIN plug?
    There will be two holes that you can screw a pin into! You actually only need 6 pins in each component so if you have a beogram , unscrew one and put it in the Beocord! The Becord and the Beogram CD use the same pin and a non RIAA Beogram uses the opposite one. I can never remember which one so experiment! If you don't have a pin, I think Martin can get you one!
