Latest post 01-27-2008 3:49 AM by Keith Saunders. 2 replies.
Page 1 of 1 (3 items)
  • 01-26-2008 12:05 PM
    • TS4
    • Not Ranked
    • Joined on 12-23-2007
    • Posts 12
    Beo 5 and Playstation 3 ??
    Hello,
    i found the PS3 in the config tool of the Beo 5. Is it possible to control the PS3 with Beo5??? The PS3 is normally controlled via bluetooth and cannot be controlled by IR!! Has anybody the solution for this? If it works this could be a nice blue ray-player for my BV7..
    TS
  • 01-26-2008 1:13 PM In reply to
    • stefan
    • Top 50 Contributor
    • Joined on 04-16-2007
    • 200 miles from Struer
    • Posts 1,733
    Re: Beo 5 and Playstation 3 ??
  • 01-27-2008 3:49 AM In reply to
    A Playstation 3 can be controlled by a Beo5 provided you have a converter of one type or another.
    There is quite a long thread on the subject HERE
    Regards Keith....
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
