Latest post 01-09-2008 4:48 PM by Jandyt. 3 replies.
Page 1 of 1 (4 items)
  • 01-08-2008 5:21 PM
    • Tim
    • Top 500 Contributor
    • Joined on 01-07-2008
    • Germany
    • Posts 114
    Programming BEO 5 for Beovision with Sat-modul Someone has a file?
    I only have a Beovision 7-32 Mark 3 (Dezember 06) with a integrated B&O Sat receiver.
    Maybe there is someone who already has a File for this configuration for the BEO5.
    Because I find the software not very intuitive this would make my life much easier!
  • 01-09-2008 2:43 AM In reply to
    Re: Programming BEO 5 for Beovision with Sat-modul Someone has a file?
    You can configure additional modules for the BV7 (look at the bottom of the config tool screen). There is a checkbox for DVB-S module, just tick it and you're done.
  • 01-09-2008 3:59 PM In reply to
    • Tim
    • Germany
    • Posts 114
    Thank you for the info - the programming (in fact - drag n drop) was quite easy.
     Everything works fine.
     In the future I will add a little bit eye candy: Logos and pictures.
  • 01-09-2008 4:48 PM In reply to
    • Jandyt
    • Top 10 Contributor
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    Glad you got into the config eventually mateWink
    Andy T.
    Poor me, never win owt!
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
