Thanks a lot, Martin
someone had put some glue to panels, i've loosen them with a lot of care. Anything is ok. The panels are black plastic with a white surface. I' ve got them off without a damage.
Wilfried
 OK, the Turntable is off, there are four screws on left and also four on the right side. you have only to lose them, don't turn them totally out. Than it is possible to take the turntable off. The RIAA cable is plugged as you told, the powercable is welded.
Do you have any idea, why the turntable turns all the time, when power is on? Also when power is switched to Tape or Radio?
