Christophe75: Hi there,
for those of you using these wonderful speakers as computer speakers, how did you connect them, how do you turn them on/off, and how do you select volume? Thank you
Christophe
Optical minijack toslink to regular toslink cable from Mac to separate Digital-to-Analog-Converter (DAC).
DACs can be had from GBP100 and up. I have a Grace M902, but a Lavry DA10 or Benchmark DAC USB will do the job excellently, and give you headphone amp's to boot.
Volume is controlled with the DAC (full volume output from the Mac to the DAC).
When I switch off the DAC, the speakers' indicator lights go red shortly afterwards.
