Latest post 04-25-2007 4:50 PM by beo-ap. 6 replies.
Page 1 of 1 (7 items)
  • 04-25-2007 11:39 AM
    Sattelite on BL1000
    I have two remotes: A Beolink Audio Terminal and a Beolink 1000. BL Audio Terminal has a button "satellite" that triggers the SAT/DTV from my Avant to a BL 2000. The BL 1000 does not have a Sattelite button. I would like to trigger the sound of the Avant to BL 3500 in another room. Is there a way to trigger Satellite with a BL1000?
    Thanks.
  • 04-25-2007 12:02 PM In reply to
    • Jandyt
    • Top 10 Contributor
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    Re: Sattelite on BL1000
    I thought all Bl 1000s had sattellite or sat on them. Have you tried 'shift TV' ?
    Andy T.
    Poor me, never win owt!
  • 04-25-2007 1:01 PM In reply to
    My BL1000 does not have a SAT button. Pressing Shift + TV = VTAPE1
  • 04-25-2007 1:16 PM In reply to
    I should be able to look that up for you tonight!
  • 04-25-2007 1:41 PM In reply to
    Thanks Peter.
  • 04-25-2007 2:25 PM In reply to
    Drawn a blank here! I take it yours is the Beolink 1000 with the second line ABC,STORE,CD ? This is an American Mk2 . Try a combination of SHIFT and then any of the other sources. Can you note down what each brings up!
  • 04-25-2007 4:50 PM In reply to
    Thanks Peter. It is I suppose an American version as it has the button combinations you describe. Until know, I've been unable to uncover a satisfactory Shift + combination.
