Hi Peter,
the reason for wanting to use both of the Bm7000's is that I have them so I thought it would be a good idea to use them both as they have speaker outputs & it also means that I have independent volume control & source selection ( or at least locally).
Referring to the IR sensor does anybody know of it as which ever way I go I will have to put the BM7000's in a cabinet,
With regards to the Beoport what sort of feedback & control do you get, also if the mac mini is connected to my Beosystem 2 for the front row aspect and I use a usb sound card connected to the mac connected to another input on the BS2 will I be able to stream say the iTunes over the Beolink while the mac is playing movies or something on the BS2
Simon
