to access the sled motor you have to disassemble a lot of parts...
- Open the cabinett, 2 screws on the back
- disassemble the cover over the drivedeck. Near the drive are 2 hooks, bend them a little bit.
- disconnect the keyboard
- disassemble the red clamps around the mainboard and disconnect the 2 cables to the powersupply and the slideframe
- disconnect the drive cables
- loose the 2 screws for the front cover and pull the front a little bit out
- the mainboard can now be mounted in a vertical position... be very carefull not to break the board. There are 2 guides and 2 steel hooks to fix it in this position
- now you can disassemble the motor, just 1 screw
Common faults are: broken gear, hard grease on the gear, bad belts, loose or lost bolts because of bad grease.
