Latest post 12-25-2007 7:47 AM by Doc. 2 replies.
Page 1 of 1 (3 items)
  • 12-24-2007 8:41 PM
    • GSHaigh
    • Top 500 Contributor
    • Joined on 04-16-2007
    • North West UK
    • Posts 163
    Configuration software update
    Hi
    Just to let you all know that there is a patch update to the config software taking it to v1.12.  Not had chance to see what's new... but will post back when I have had chance to play.
    Greg
  • 12-25-2007 1:48 AM In reply to
    • Quim43
    • Top 75 Contributor
    • Joined on 11-15-2007
    • Tarragona (Catalonia)
    • Posts 1,030
    • Gold Member
    Re: Configuration software update
    Hi
    I got this patch some weeks ago, it updates your Beo5 software to 1.20a, and just fix some problems with USB port to recognize your Beo5. I guess we are talking about the same patch.
    Regards
    Quim
  • 12-25-2007 7:47 AM In reply to
    • Doc
    • Top 150 Contributor
    • Joined on 04-17-2007
    • Posts 585
    From which location should the Beo5CTPatch_1.02-file be opened?
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
