I purchased my current B&O A/V system in 1994, with the following components: (1) Beosound 9000 CD Player, (1) AV 7000 Tuner, (2) Beolab 4000 Speakers, (2) Beolab 8000 Speakers, and a Beolink converter. Although esthetically pleasing, the AV7000 is somewhat dated in its technology and functionality.
When I originally purchased the equipment I had a multi-room application. I now have a have a single room surround sound application. I want to incorporate the two pair of speakers in a 6.1 channel speaker system powered by a Sony STR-DG 1000 tuner. I want to utilize the Beolab 4000's as "Center" speakers, and the Beolab 6000's as "Front" speakers.
In the original system both pairs of these "Active" speakers were connected via 8 pin "Powerlink" cables. Both pairs have optional RCA "LIne" jacks, so I assume I can connect them to the Sony tuner using RCA type line cables with "Banana Jacks", and changing the on-speaker switches to "Line". My problem concerns the output of the Beosound 9000 to the Sony tuner. In my multi-room set-up it was linked to the AV7000 through a "Masterlink", and the Beolink Converter.
My questions are:
1) Is there an 8 pin powerlink to RCA cable adapter that will enable me to send the Beosound 9000 CD signal to the Sony tuner?
2) Is it safe to hook-up the high wattage Sony tuner to the B&O active speakers?
I would opt to continue using the AV7000, but the Sony has more bells & whistles, and I really don't want to set-up the ugly infra red sensors on my other components. I assume I would have to continue using the Beo-4 Remote to control the Beosound 9000.
Thanks for any advice you can give me.
