thanx 4 your response----here it is--
I have an a beosystem 2300( cd only no tape deck)---it is the older 2300 with speakers attached to the sides, bracketed
to wall. There are 2 ports for this 7 pinned access cable I go from b&o---the only port left has a cable that goes to a outlet
installed to run to the area where the installer has all the other b&o speakers (with electronic eyes) that passively work off the main
system (beo 2300). I want to hook up my i pod with this access cable---but the only port available is the one that
links the passive speakers. If I take that cable out, plug in access. cable for i pod I can run i pod on the main sys
ONLY--my goal is to get the rest of thi house to be connected to i pod. How can I do this with only 1 accessory port???
is there some time of splitter that I can use to plug i pod and master cable to??? Thanx--dealer not much help!! regards Brenda L
