Latest post 12-22-2007 12:44 PM by williams22. 4 replies.
Page 1 of 1 (5 items)
  • 12-22-2007 11:38 AM
    Can it be done!!
    I am wondering if it is possible to have a Beosound 4 and a Beosound 9000 in the same link system as i would like to be able to access a seperate radio up stairs or will they interfer with each other. When i listen to radio upstairs at moment from Beosound 9000 on g/floor it turns the radio on in the other link tv so would like a second radio or is only way a beocentre 6 with radio built in.
  • 12-22-2007 11:47 AM In reply to
    • Christian
    • Top 100 Contributor
    • Joined on 04-16-2007
    • Copenhagen, Denmark
    • Posts 626
    Re: Can it be done!!
    I suppose it can be done.
    You will not be able to hear any sources on the BS4 in the link system, but in the room where the BS4 is, you will have a choise of either local sources (FM and CD) or link-sources from the BS9000.
    Christian
    Living room: BV7-40 mkIV + V8000, BL5, BL3, BM1 and BS9000. Bedroom: MX3000 and BL4500 on MCL2-AV. Around: PentaIII, CX100 and MCX35 on ML/MCL + MCL2-A, BeoPort and BL4 on ML, BS3300 + M75 as stand alone, BC6000 + BC600 and BT1100, LC1, LC2, Beo4, Beo5 and BL1000, BS2 and A8, EarSet2, Apron, Coffee mugs, Enamel Bagdes, Bath towel, Keyring, Books, Lots of miniature and the Bottle opener. Office: BC2300 + BL2500 and BS3. Summer house: BS Century.
    Addicted? Oh no.... ;)
  • 12-22-2007 12:28 PM In reply to
    ok i did try it earlier but when i pressed Radio on a link tv i  could hear both radios over each other, is this because i had the Beosound 4 in the wrong option, i had it in option 0 do you think it should be in 1 or 2. Thanks for your advise!!
  • 12-22-2007 12:37 PM In reply to
    • Christian
    • Posts 626
    It needs to be put in slave mode.
    However, I am on christmas holiday away from home, hence I do not have my manuals, so I am not certain. Try option 4, and try also to have a look at: www.beotech.co.uk
  • 12-22-2007 12:44 PM In reply to
    Will try option 4 and look at site Thanks for help.
