Latest post 07-12-2011 1:11 PM by beo-ap. 18 replies.
Page 1 of 1 (19 items)
  • 12-21-2007 6:34 AM
    B&O wireless
    I have begun this thread to find out more information about B&O wireless as I call it. I don't even know the proper name! I am also interested to hear any positive and negative comments about this product from those who own one.
    My B&O dealer has only ever once spoken about this product with me, and that was when he first had a few in stock. So does this mean they are not really selling? As far as I know, you require a central station which can be hidden away, and then receivers which are attached to your BeoSound, BeoVision and BeoLab 3500 for example. Is this correct?
    My final question is: How much are B&O charging / ripping us off for the B&O wireless?
    Thanks in advance! Yes -  thumbs up
  • 12-21-2007 10:27 AM In reply to
    Re: B&O wireless
    Henry,
    I do not own a "Beolink Wireless 1" which is its formal name and I think it is unlikely that I ever will. However when it was first released I did review the product in some depth.
    When it was first released, the Beolink Wireless 1 could only work with the new version of Beolab 3500 which had updated software and Powerlink sockets, since that time there has been a recently introduced update version 2.1 software which allows complete Masterlink compatability as well as Powerlink.
    The new BeoLink Wireless 1 can in functionality be compared to a Beolink Active, driving a pair of active speakers in a link room. The difference is that the Master Link connection to the main room set-up is now wireless.
    A wireless link set-up always consists of minimum two BeoLink Wireless 1 units. One BeoLink Wireless 1 operating as transmitter will be placed in the main room and one BeoLink Wireless 1 operating as receiver in the audio link room.
    BeoLink Wireless 1 is based upon the WLAN (Wireless local-area network) technology This technology is using the 2.4 GHz band which is also used by many other wireless devices, for example WiFi, wireless LAN transmission and cordless telephones (DECT). The technology transfers sound and control commands only, not video signals which will still need to go via a coax cable. The sound quality provided by BeoLink Wireless 1 is of high quality, transferring uncompressed PCM stereo, which is equal to CD quality.
    Depending on the placement, thinkness of walls, material and surroundings, BeoLink Wireless 1 has an indoor range of approximately 30 m (100 feet).
    The Beolink Wireless 1 comes in either black or white and would be purchased in pairs. A switch on the unit defines if it is a transmitter or receiver.
    Regards Keith....
  • 12-22-2007 11:41 AM In reply to
    Re: B&O wireless
    Thanks for your informative and very cleary structured post Keith.
    In this case, does this mean I can use the speaker of a BeoVision as a link speaker in another room using the BeoLink Wireless 1?
    And finally, does anyone know how much this kit costs? ... Lee do you have one? Cool
  • 12-22-2007 11:54 AM In reply to
    • Christian
    • Top 100 Contributor
    • Joined on 04-16-2007
    • Copenhagen, Denmark
    • Posts 626
    Re: B&O wireless
    Last time I cheked, it was priced at 2.600 DKK (=350 € or 260 £) per unit. Each unit can act both as transmitter or reciever.
    Living room: BV7-40 mkIV + V8000, BL5, BL3, BM1 and BS9000. Bedroom: MX3000 and BL4500 on MCL2-AV. Around: PentaIII, CX100 and MCX35 on ML/MCL + MCL2-A, BeoPort and BL4 on ML, BS3300 + M75 as stand alone, BC6000 + BC600 and BT1100, LC1, LC2, Beo4, Beo5 and BL1000, BS2 and A8, EarSet2, Apron, Coffee mugs, Enamel Bagdes, Bath towel, Keyring, Books, Lots of miniature and the Bottle opener. Office: BC2300 + BL2500 and BS3. Summer house: BS Century.
    Addicted? Oh no.... ;)
  • 12-23-2007 1:01 PM In reply to
    Re: B&O wireless
    If you have a Beovision in a link room you can use it effectively as a Beolink Active as you would if it were hardwired.
    Generally, I would only suggest using a Beolink Wireless 1 in situations where there is no way of using a cable because of cost and potential interference issues particularly when a microwave oven is used near one of the units.
    Regards Keith....
  • 12-23-2007 2:34 PM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Re: B&O wireless
    Agree with Keith, if you can do it with a cable then forget the wireless solution. Both my home and office at work have wired networks for the PC instead of wireless. Just not a fan of wireless at all myself.
    CraigSmile
  • 12-26-2007 4:43 PM In reply to
    Re: B&O wireless
    be careful if you own a microwave oven (which almost everyone does.)
    jazz
  • 01-05-2008 3:54 AM In reply to
    • Uli111
    • Not Ranked
    • Joined on 01-05-2008
    • Posts 6
    Re: B&O wireless
    Keith,
     My BeO dealer told me that I couldn't use the Beolink Wireless for my rear speakers (Beolab4) for surround sound.
    But you mentioned that Beolink Wireless has nearly te full Masterlink functionalities.
    Am I correct that I can set up a surround setting with BeO rear speakers with Beolink Wireless? (Front speakers are cabled)
    Best regards,
    Uli
  • 07-09-2011 12:38 PM In reply to
    • frog
    • Top 500 Contributor
    • Joined on 04-19-2007
    • Posts 191
    Re: B&O wireless
    I'm using a couple of Beolink Wireless 1's as ML-bridges and they work fine (once programmed to the same software release 2.1E (I think)) - but the TIMER function from the main system doesn't seem to work - I think that this is because the BW1s go to sleep and the transmitter misses the TIMER signal from the main system.... maybe...
  • 07-09-2011 7:46 PM In reply to
    Re: B&O wireless or a wire and a carpet
    Buy a carpet, lay it out between your TV-set or beosound xyz and your rear speakers and bury the cable to the rear speakers under the carpet ...
    iPoditiv
  • 07-10-2011 2:26 AM In reply to
    • pf85
    • Joined on 04-21-2007
    • Posts 145
    Re: B&O wireless
    frog:
    I have BL Wireless from the main room into two other rooms. Works fine and is robust. Most elegant way to manage timer functions is with Beotime, even with commands from the link room...should solve the problem.
  • 07-10-2011 6:23 AM In reply to
    • frog
    • Posts 191
    Re: B&O wireless
    You're right! The test I did failed to start up on the Wireless connected Overture - but the repeating timer kicked in and worked this morning. I suspect that there was some 'settling in' time needed by the ML system.
  • 07-10-2011 11:31 AM In reply to
    • Stan
    • Top 150 Contributor
    • Joined on 04-17-2007
    • Posts 593
    • Gold Member
    Re: B&O wireless
    I wake up to my BL4s via a beolink wireless every day.  It works fine.  I did have to upgrade the software after I bought the wirelesses.
    Question:  Do you have multiple ML devices connected to your wireless (when you say you have it working as a "bridge")?  I'd like to connect a passive to my wireless (and once you use it as a bridge, you cannot use the wireless's PL ports anymore - I have tested this) which means wireless + active + passive... which seems like it should work...  but you never know until your try... have you tried this?
    Thanks,
    Stan
  • 07-10-2011 1:12 PM In reply to
    Re: B&O wireless
    Hi
    One question is still open: can one use Beolink wireless for driving rear surround speakers?
    BeoVision 8-40 / BeoVision 8-32 / Beovision 6-26 / BeoSound 3200 / BeoSound 1 / BeoLab 3 /  Beolab 6000 / Beolab 2000 / Beoport / Beomedia 1 / 3* Beo4 /BeoCom 5 with VOIP
  • 07-10-2011 4:16 PM In reply to
    • Stan
    • Posts 593
    • Gold Member
    Re: B&O wireless
    I don't think so.  The Wireless unit works with 2 channel audio that is sent on the MasterLink network.  That is, MasterLink is the only method of getting audio into a wireless transmitter.  I don't believe that it is possible for the TV to send only the rear channel audio to MasterLink. If there is way to do this, then it would probably work as the wireless does not introduce any perceptable delay (at least I cannot hear any).
    Stan
  • 07-10-2011 8:13 PM In reply to
    Re: B&O wireless
    I can vouch that the Bosscom wireless PL option is very robust and we've used it in a few installations now. Its price could potentially outweigh the cost of actual installation, but where the structure is particularly challenging it's a life saver.
    There is scarcely anything in this world that some man cannot make a little worse and sell a little more cheaply. The person who buys on price alone is this man's lawful prey. - John Ruskin
  • 07-11-2011 6:09 AM In reply to
    Re: B&O wireless
    Trip,
    In the UK not too long ago, anything with the "B" word on it was frowned upon - a lot.  Up to and including not honouringa warranty repair if anything from B was used in the install - PL, ML, connectors etc etc.
    Not sure if that is still the case, having stepped back from the front line, but there was a LOT of hostility to Bosscom a couple of years ago.
    DJ
  • 07-11-2011 7:40 AM In reply to
    Re: B&O wireless
    Interesting to know. Bosscom doesn't have nearly the same presence with the US dealers, so we may have skipped an unfortunate period.
  • 07-12-2011 1:11 PM In reply to
    Re: B&O wireless
    Trip,
    Where can one source Bosscom in the US? Thanks.
