Yes, this is a common issue when it does not automatically install.
It is looking for a file called "Beo5Usb.inf" located in the following location:-
C:\Program Files\Bang & Olufsen\Beo5 Configuration Tool\Beo5Driver
You will need to manually browse to it and you will have to tell it the location twice.
