Latest post 04-25-2007 3:26 PM by Graeme. 9 replies.
Page 1 of 1 (10 items)
  • 04-24-2007 3:39 PM
    • Graeme
    • Top 500 Contributor
    • Joined on 04-16-2007
    • Aberdeenshire Scotland
    • Posts 194
    Ouverture to Lab Penta's cables
    Hi Guy's
    http://www.beoworld.org/prod_details.asp?pid=952
    Can anyone tell me the cables required to link Lab Penta's to an Ouverture? Am I right in thinking powerlink cables will do the job. What about Speakerlink cables, would they work too?
    Cheers
    Graeme
    Cheers Graeme
  • 04-24-2007 3:46 PM In reply to
    Re: Ouverture to Lab Penta's cables
    If they are Penta II's or III's then you need Mk2 powerlink cables. Speakerlink cables will not plug into the Ouverture.
    Regards Graham
  • 04-24-2007 3:56 PM In reply to
    • Graeme
    • Posts 194
    Cheers Graham
    Mine are III's, so what is the difference between powerlink and Mk2 powerlink. Is there anywhere I can see pictures showing the difference?
    Cheers Graeme
  • 04-24-2007 4:01 PM In reply to
    Mk2 powerlink are slightly thicker than the others and the plugs are "fully wired". ie All the pins are connected. In this way you will get the displays on the pentas working.
    Regards Graham
  • 04-24-2007 4:05 PM In reply to
    • Graeme
    • Posts 194
    Thats why I would like to see them cos my BC9000 with speaker link gives me the display's with 4 connections.
    How many connections on powerlink and mkII powerlink?
    Cheers Graeme
  • 04-24-2007 4:43 PM In reply to
    I think you need a minimum of 5 conductors for each speaker if you were going to make up some cables
    Left or right signal, signal ground, 5v to switch on, 0v, digital signal and possibly one other. I assume that beotech is down so can't check this. Any way, I'm fairly sure you can't do it with 4.
    Regards Graham
  • 04-24-2007 5:09 PM In reply to
    • Graeme
    • Posts 194
    Does that mean that speakerlink maybe share lines? Speaker link has 3 round pins in a trianlge with flat bar in the middle of the triangleConfused sorry just trying to make sence of thisEmbarrassed
    Cheers Graeme
  • 04-25-2007 11:54 AM In reply to
    • Graeme
    • Posts 194
     In light of the amount of querries regarding cables/connections, compatibility etc, would it not be very valuble to have a matrix type sheet showing the different B&O connections, how they work, were they fit and were they don't.
    Cheers Graeme
  • 04-25-2007 1:18 PM In reply to
    • Christian
    • Top 100 Contributor
    • Copenhagen, Denmark
    • Posts 626
    joeyboygolf:
    BeoTech is working... http://www.beotech.co.uk/
    Living room: BV7-40 mkIV + V8000, BL5, BL3, BM1 and BS9000. Bedroom: MX3000 and BL4500 on MCL2-AV. Around: PentaIII, CX100 and MCX35 on ML/MCL + MCL2-A, BeoPort and BL4 on ML, BS3300 + M75 as stand alone, BC6000 + BC600 and BT1100, LC1, LC2, Beo4, Beo5 and BL1000, BS2 and A8, EarSet2, Apron, Coffee mugs, Enamel Bagdes, Bath towel, Keyring, Books, Lots of miniature and the Bottle opener. Office: BC2300 + BL2500 and BS3. Summer house: BS Century.
    Addicted? Oh no.... ;)
  • 04-25-2007 3:26 PM In reply to
    • Graeme
    • Posts 194
    WOW! I have never been on beotech before, great site. Should there not be a link on the links page for it?
    Cheers Graeme
