Latest post 04-24-2007 5:23 PM by BenSA. 4 replies.
Page 1 of 1 (5 items)
  • 04-24-2007 3:35 PM
    • simonbring
    • Not Ranked
    • Joined on 04-23-2007
    • Stockholm, Sweden
    • Posts 29
    • Silver Member
    Beomaster touch glass panel wont work 3500 4500 8500 9000 9500
    Hello!
    I recently removed the glass panel on my BM 4500. When I put it back on, the touch panel does not work as it did before.. Many of the "buttons" do not function any more. Anyone got any idea about what happened?
     Thanks,
    Simon
  • 04-24-2007 3:42 PM In reply to
    Re: Beomaster touch glass panel wont work 3500 4500 8500 9000 9500
    If you fix it back on with glue or tape that is too thick you can get this effect.
    Regards Graham
  • 04-24-2007 4:07 PM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Thin Carpet tape works very well. Fixed my Beocenter9000 a treat.
    CraigBig Smile
  • 04-24-2007 4:42 PM In reply to
    • simonbring
    • Not Ranked
    • Stockholm, Sweden
    • Posts 29
    • Silver Member
    Well, I have not used anything to fix it back on at all... The plastic frame seems to fit alright without refixating it. I thought it had something to do with the small rubber sensors under the glass panel...?
  • 04-24-2007 5:23 PM In reply to
    • BenSA
    • Top 75 Contributor
    • Joined on 04-16-2007
    • Durban, South Africa
    • Posts 808
    • Gold Member
    I had the same problem when I replaced the glass on my Beomaster 3500, some wouldn't work. When you put the glass with the plastic frame back on the sensor board it slides to one side. The sensors then bend and don't stand up straight. This is fine, they are supposed to do this. If you take something and straighten them they don't work. You can also check where the sensor end is touching the glass, that is, it must touch the right part of the glass where you would touch it with your finger. This is what I have experienced.
    Durban South Africa
