Latest post 12-19-2007 6:01 PM by ttshinykit. 11 replies.
Page 1 of 1 (12 items)
  • 12-19-2007 3:25 PM
    Beolink 5000 - Beosound 3000
    I've picked up a beolink 5000 remote with a beosystem 2500, the remote works fine with the 2500 but does not work with my Beosound 3000!! Does anyone know if they are not compatible.
     Also, I had the BS3000 playing through my Avant tv which is now gone. I now have some beolab 6000's connected to the BS3000 but the system must be set to just play through the tv (option 0 on the audio set up) as whilst I have sound coming through the 6000's I have no volume control atall. I do not have a Beo4 remote, is this the only way of switching the audio set up for option 1.
  • 12-19-2007 3:40 PM In reply to
    Re: Beolink 5000 - Beosound 3000
    The Beosystem 2500 you use probably had two way communication. the BS3000 doesn't have this feature. You can use a Beolink 5000 with the BS3000 if you set it to one way communication. Unfortunately, I don't remember how you do this right now.
  • 12-19-2007 4:08 PM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    If you remove the batteries when you put them back in I think it will go in to one way mode.
    CraigSmile
  • 12-19-2007 4:09 PM In reply to
    • Ignace
    • Top 25 Contributor
    • Joined on 03-30-2007
    • Moderator - NL
    • Posts 2,749
    Beolink 5000
    - How can I set the Beolink 5000 from 2 way into 1 way ?
    * press and hold Stand-By untill the display shows: STD. BY SYSTEM
    * press SHIFT , MENU
    display shows: TRMINAL SETUP?
    * press PLAY
    display shows: VIDEO TWO WAY
    * press arrow up/down to select
    * PLAY
    * arrow up/down
    * PLAY
    display shows: TRMINAL ACCEPT?
    * PLAY
    Beolink 5000 will return to stand-by and is now set to 1-way
  • 12-19-2007 4:10 PM In reply to
    • Ignace
    • Moderator - NL
    • Posts 2,749
    Craig:
    CraigSmile
    It's the other way round, it will go into 2-way Smile
  • 12-19-2007 4:16 PM In reply to
    • Craig
    • Posts 4,855
    Ignace:
    Craig:
    CraigSmile
    Thanks Ignace, I remember reading a few threads about loose contacts and presumed as most people use them in two way it reverted back to one way.
    CraigSmile
  • 12-19-2007 4:17 PM In reply to
    I've set the beolink 5000 to one way audio mode, but still no response from the beosound 3000!!
  • 12-19-2007 4:34 PM In reply to
    would i need to 'pair' the remote to the BS3000 or should it work automatically?
  • 12-19-2007 4:48 PM In reply to
    Your beosound is in the wrong option, thats why it don't work.
    should be option 1
  • 12-19-2007 5:38 PM In reply to
    • Ignace
    • Moderator - NL
    • Posts 2,749
    In stand-by, press SOUND, 1, STORE.
    BM3500 will show : O P 1
  • 12-19-2007 5:39 PM In reply to
    With the BS3000 in standby.
    Try SOUND 1 STORE on the Link 5000
    That should put it into option 1
    Regards Graham
  • 12-19-2007 6:01 PM In reply to
    ok, i'm not worthy, thanks for all your help everyone, Ignace & Graham, bang on, did as you said and the bs3000 blinked once, all done!Big Smile
