Latest post 12-23-2007 1:15 PM by Dillen. 3 replies.
Page 1 of 1 (4 items)
  • 12-19-2007 1:39 PM
    2400 or 2400-2 with my Beogram 4004?
    If this is the wrong board, I apologize.
    I want to use my Beogram 4004 with a B&O system that has remote control.
    In the US, the 2400s come up with remote from time to time, but the 2400-2s are harder to come by.
    Do I definitely need the 2400-2 to have remote control functions to the 4004?  Are the remotes that came with the 2400 vs. 2400-2 different from each other?
    Chris
  • 12-19-2007 1:51 PM In reply to
    Re: 2400 or 2400-2 with my Beogram 4004?
    I don't think the remotes differ but the 2400 does not have the 7 pin DIN connection to attach the 4004 only a 5 pin (just had a look at the service manual). Therefore to get remote control, you need the 2400-2.
  • 12-19-2007 1:54 PM In reply to
    the remotes are not different, i *believe* that the difference w/ the -2 was that you could initiate the beogram from the bm and/or remote. i will chk my notes.
    (3) 2400-2 and (2) 4002 -though not connected...
    ++++edit++++
    per my notes (peter above)
    the -2 allowed the play and stop of the bg from the bm a/o remote
    • B&o bottle opener
  • 12-23-2007 1:15 PM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Generally the above is correct though I have seen a few BM1900/1900-2 and 2400 that were converted for use with the Beogram 4004 (and 2404). The BM1900 won't allow remote control but the 1900-2 could be upgraded. All 2400 and 2400-2 has remote control.
    The safest thing is, as mentioned above, to check the turntable DIN socket, it needs to have 7 pins to remote operate the Beogram.
    The remotes are all the same.
