Latest post 12-19-2007 3:43 PM by Gerd. 1 replies.
Page 1 of 1 (2 items)
  • 12-19-2007 12:46 PM
    • KaRsK
    • Not Ranked
    • Joined on 12-03-2007
    • Posts 2
    Beo5 . can i upload xml file from beo5 to my computer
    or do i need to get my beo5 xml file from my dealer ?
    Don`t want to start making a xml file from the beginning  :)    (  it is easy`r if i can see how the dealer did it )  :)
    KaRsK
    Norway
  • 12-19-2007 3:43 PM In reply to
    • Gerd
    • Top 150 Contributor
    • Joined on 04-20-2007
    • Germany
    • Posts 523
    Re: Beo5 . can i upload xml file from beo5 to my computer
    No, you can't! Try to get it from your dealer or start making your own one.
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
