I have a Com 2 with a cut cable. It is the slightly earlier model with a jack plug going into the transformer.
1 How easy is it to re-wire?
2 Where can I get a cable ?
Thanks in advance
Jonnie
Anyone? Keith????
Stripped it down. Easy repair, part ordered.
Jonnie,
Sorry I missed your post, but pleased that you seem to have everything sorted. If you have a problem once you have the part, then let me know.
Regards Keith....
