Latest post 12-19-2007 5:30 PM by frankmj. 12 replies.
Page 1 of 1 (13 items)
  • 12-18-2007 3:36 PM
    tried aux socket on mx4002. Now ML doesn´t work
    Hi!
    I tried the aux socket on my mx 4002 connected to a Bm7000 and mx6000 through a converter. I remowed the converter and connected the aux cable directly. After this my V8000 doesn´t respond to any commands from the bedroom when I connected the converter again. The tv works in the same way as when connected to aux. How can I reset this back to normal??
    Regards
  • 12-18-2007 4:06 PM In reply to
    Re: tried aux socket on mx4002. Now ML doesn´t work
    Disconnect everything from the mains. Re-connect as you want it. Then connect to power again.
    Regards Graham
  • 12-18-2007 11:46 PM In reply to
    Hi!
    Doesn´t work unfortunately. There was a small plastic cover over the aux socket. Is it important. I have lost it. But it was just a small piece of plastic
  • 12-19-2007 6:20 AM In reply to
    Perhaps there is a setting in the service menu to set the MX to ML or AUX?
  • 12-19-2007 6:29 AM In reply to
    • cozza
    • Top 500 Contributor
    • Joined on 04-18-2007
    • New Zealand
    • Posts 119
    Have you depowered the Beolink converter? It will automatically configure when powered up. There is no option in the MX service menu to select between AAL and ML.
  • 12-19-2007 8:12 AM In reply to
    Yes! I depowered everything including converter. I`m acutally beginning to suspect my mx 6000. It doesn´t respond to any command from MCL or ML. I have MCL and speakerkit in kitchen and it doesn´t respond to commands from there either. When I connected the 4002 to aux I actually had two tv sets connected the same way at the same time to beomaster 7000. I used a y-cable. Can this have messed things up in mx 6000. At the same time I had a mx 5000 in another linkroom connected through a proper mcl video unit. Everything has worked fine until now.
    Do I have to do some option programming again. If yes, update me on the options:
    Room 1. Bm 7000 + MX6000. I like to have them in option 1 because of speaker config. Penta to mx and vox 5000 to Bm 7000
    Kitchen. MCL speakerkit + cx 50
    Bedroom1: Mx 5000 to videokit (mcl)
    Bedroom2: MX 4002 to converter to y-cable and datalink in Room 1
    regards
  • 12-19-2007 9:34 AM In reply to
    Hi
    I have now tried almost everything, found all options and reprogrammed but mx 6000 doesn´t respond from linkrooms. I have tried disconnecting all other equipment and adding one by one but nothing.... Maybe the mx 6000 doesn´t know it´s a videomaster anymore?
    regards
  • 12-19-2007 9:43 AM In reply to
    One more thing: Everything else works fine in all rooms. If I start MX6000 directly in localroom I can move sound to linkrooms but I cannot change channels etc from linkrooms. So I´m quite sure the MX 6000 doesn´t know it´s a master anymore???
    regards
  • 12-19-2007 2:45 PM In reply to
    • cozza
    • New Zealand
    • Posts 119
    Could be that the MX6000 has a bad solder connection on the Aux DIN socket data pin, or a broken wire in it's Audio Aux cable. That would cause the lack of response from the link rooms.
  • 12-19-2007 2:51 PM In reply to
    Ok!
    So, even if it responds to commands from bm7000, for example AV CD it still can mess up link room commands?
    I´ll have to check
  • 12-19-2007 3:21 PM In reply to
    I tried to change cable, nothing.
    One more queston: can i change mx 6000 with mx 5000 as master? Or even use mx 4002 as master?
    regards
  • 12-19-2007 3:28 PM In reply to
    I´ll answer myself. Changed mx 6000 for 5000. Worked fine from kitchen. Must be a faulty 6000 then
  • 12-19-2007 5:30 PM In reply to
    hagan:
    regards
    The MX4002 can't be a Video Master, unless you remove the ML module and change the software, then it will become a MX4000.
    /Frank
