Latest post 12-17-2007 6:45 PM by ipaul. 9 replies.
Page 1 of 1 (10 items)
  • 12-17-2007 9:38 AM
    Picture in Picture module
    Hi:
    I have a basic understanding of electronics and have built and stripped down PCs in the past. Thus if I bought a PinP module for my Avant would it be like installing say a PCI card or ram upgrade in a PC. Also I have heard I would need a special screwdriver - is this B&O specific or could I get it from a hardware store?
    Graham
  • 12-17-2007 10:08 AM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Re: Picture in Picture module
    Graham, if it is like the one for the MX5000 then it is just plug and play. Not sure about a special Screwdriver. Would imagine it just a Torx type so easily available.
    CraigSmile
  • 12-17-2007 10:32 AM In reply to
    Hi:
    Thanks what is a Torx screwdriver - star drive/philips?
    Graham
  • 12-17-2007 10:57 AM In reply to
    You need a splind screwdriver, more manufacturers are using them now, but can be purchased from Halfords in the UK because they are also used on cars.
    Regards Keith....
  • 12-17-2007 10:58 AM In reply to
    • kallasr
    • Top 75 Contributor
    • Joined on 04-19-2007
    • Willich, NRW, Germany
    • Posts 1,077
    d) is torx                         ( c) is phillips)
    Ralf
    My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD,  Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
  • 12-17-2007 11:06 AM In reply to
    Hi:
    Thanks, you learn something new every day - I also like messing around with old Jags and I often use star drive sockets which is what that is. I probably invented that term but am glad I know the right term now...
  • 12-17-2007 11:16 AM In reply to
    kallasr:
    Ralf
    Incorrect, b) is phillips and c) is posidrive
    Regards Graham
  • 12-17-2007 12:27 PM In reply to
    And (d) is the one you will need for the job
    Regards Keith....
  • 12-17-2007 2:04 PM In reply to
    • kallasr
    • Posts 1,077
    joeyboygolf:
    kallasr:
    Ralf
    Ok, I should have paid better attention to the english wikipedia ...
    Sorry for the confusion.
    Ralf
  • 12-17-2007 6:45 PM In reply to
    .....And the installation of the PIP module depends of the type of Avant, but you could do it i think, i did one on the T8111 which is installing the board  (yes: with the torx screw, and you'll needs torx (15 i think) to open the Avant).
    Plug one connector in and cut 4 jumpers on the board behind it, for the later Avants it might be different again...
