Latest post 01-06-2009 1:49 PM by OKF. 7 replies.
Page 1 of 1 (8 items)
  • 12-16-2007 11:25 AM
    Light scenes with Busch Jaeger B&O Control Panel
    With my Busch - Jaeger Control Paneal (B&O version) I have set up different scenes.
    With Beo4 I can select them with LIGHT <red>, LIGHT <blue>, LIGTH <green> and LIGHT <yellow>.
    If I do this with Beo5, nothing happens. I am only able to control a LC2.
    The code i.e. send is
    0:000:LIGHT:LIGHT:+0.000:LIGHT:CNTL_STEP_DW
    Is there any body with a similar problem?
  • 12-17-2007 12:36 PM In reply to
    Re: Light scenes with Busch Jaeger B&O Control Panel
    Your Busch - Jaeger Control Panel is like the Lutron unit as far as remote control is concerned and I have set these up without problems.
    See below a picture of the setup and associated commands:-
    Lutron
    Regards Keith....
  • 12-18-2007 7:57 AM In reply to
    Hello Keith,
    I think there is a difference. With your Lutron the way of addressing is similar to the LC2.
    You push the Ligth button, the a number to address it.
    With the busch-jaeger I have to push ligth, and then of the function keys. (red, green, yellow, blue). It seems, that the remote
    does not send this combination.
    regards,
    sethach
  • 12-18-2007 9:12 AM In reply to
    Sethach,
    The Lutron is similar, but not the same. Lutron also use the coloured buttons for difference scenes, so on the Beo4 I press the light button then a coloured button. I do NOT need to press a number button.
    What I showed you in the previous post was the actual working coloured buttons for Lutron which in my view should be the same as Busch-Jaeger. The only thing I would say is if the Busch-Jaeger does not decode the first instruction quickly enough, it may miss the second, so you may wish to put a delay between the two commands.
    Regards Keith....
  • 12-18-2007 2:40 PM In reply to
    • Doc
    • Top 150 Contributor
    • Joined on 04-17-2007
    • Posts 585
    Keith,
    With which program did you make the buttons?
    Is it downloadable from internet?
    Thanks.
  • 12-19-2007 7:20 AM In reply to
    I used a program called "Crystal Buttons" from www.crystalbuttons.com its not free, but it does the job.
    If you want any of the buttons I have already produced, then you can download them from HERE
    Regards Keith....
  • 01-06-2009 10:53 AM In reply to
    • OKF
    • Top 500 Contributor
    • Joined on 02-22-2008
    • Posts 204
    It works with a 250 delay in between at least with the old software. With the brand new I cannot put a delay inbetween and therefore I cannot get the 4 funktions working. When I set delay it says error?
    This is how it was and should be
    0.000.LIGHT.LIGHT
    delay 250ms
    0.000.LIGHT.CNTL_STEP_UP
    but it shows:
    0.000.LIGHT.LIGHT
    error!
    0.000.......
    Any idea?
    Best regards Oliver
  • 01-06-2009 1:49 PM In reply to
    • OKF
    • Posts 204
    git it and there will be another software update as this one is faulty, the 'error!' instead of the delay is right and it only does work with 'error!' inbetween. Anoying that B+O does not get it right, also the BJ Panel is in B+O components and in non-B+O components and I suggest to use the first one. The other is the old and also works with the 'error' config which is not desireable I guess.
    Best regards Oliver
